#373353 08/07/16 07:42 PM
Zippy Offline OP
Can anyone explain how to install a harmonic balancer on the 207 engine? I can take it off but can't figure out how to reinstall it. Would appreciate any help.
Drive it on with a big hammer. first bolt it together using bolts in the puller holes. I use a big piece of pipe that just fits around the crank attachment in the center.
Make sure it is fully "ON"....it will go on easier than you think.
I have installed a few using an appropriate size block of
hard wood to absorb the blow of the hammer. Good luck!
flip
Zippy Offline OP
Thanks to both of you.I have the original shop manual and it shows a tool to remove and replace the balancer and even explains how to do it, but it's impossible.
