What kind of material is used in a 1937-1938 business coupe, for the rear shelf under the back window...inside the cabin.
Posts: 1,894 |
The deck is approx. 3/4" plywood on mine with a vinyl like material that matches the kick panels. The vinyl appears to originally be tan or light brown but has silver streaks from age.
I know Tiny had some pictures on here somewhere as well and mine was the same.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
X2 Below are a few pics. I'm using links instead of embedding them into the thread so you get a larger image. I may have more in my archive but I'm not on that computer right now. Image 1 Image 2 The vinyl is the same color shown here on the kick panels and seat side panels. The package shelf vinyl is attached to a heavy paperboard, not fastened directly to the wood. The vinyl/paperboard is also floating on the package shelf, not fastened to it.
Tim tells me he can't open the links so here they are embedded. Image one Image two Image three ![[Linked Image from i47.photobucket.com]](http://i47.photobucket.com/albums/f167/Tinys1938/IM000842-1.jpg)
Thank You guys
