ParisTX Offline OP
Hello I'm new to vintage Chevy's & this site. I have a 1931 Chevy 2 door 5 window coupe.
Looking for brake lining material. As I'm trying to keep car original. No hydraulic brakes.
I read an old article about a Mooney's part place in TX; but appears to be closed. I already looked online at the Filing Station.
Thank you & look forward to chatting & learning from some good people with VCCA.
Lewis Brake & Clutch, Albuquerque, NM 505 247-1405
If you have old Chevrolets, other old Chevrolets will find out where you live.
I buy high strength lining strips from McMaster Carr. Then I install them myself on the shoes. Several others have also installed McMaster-Carr lining material. All so far have been satisfied with the stopping power. Cars range from 1927 to 1933.
ParisTX Offline OP
Thanks!
ParisTX Offline OP
Thanks!
What thickness do you use?
Paul
If it isn't broken, fiddle with it anyway so you have something to repair.
1931 Deluxe Sport Roadster
1953 BelAir 4 dr. Sedan
1965 Chevy II Nova SS
ParisTX Offline OP
I have no idea as to thickness - recently purchased Chevy. But great question.
I'm just assisting mechanic with locating brake linings & a couple other items.
On McMaster Carr they have several. And on Vintage Auto parts I found a set for
Chevy's 1928-1940 $78. But doesn't mention thickness.
Do they need to contain asbestos? As the original? (NOS/NORS). It seems asbestos is not preferred & is it really needed? But then again I'm sure there are other lead/asbestos parts.
3/16"
On McCarren Carr they have several
It's "McMaster-Carr". http://www.mcmaster.com/
another post about this subject with info/ details:
Braking with 1929 stock mechanical brakes
ParisTX Offline OP
Thank you BearsFan315
