Posts: 14 |
My rear axleshaft broke. Does anyone know a source where to get a replacement? Does anyone have experience with vintage Auto parts? They seem to offer axle shafts. It seems that the axle shafts that are mounted now are replacements already. Does anyone know a source for original rear brake drums? I#M looking forward to your hints.
Matthias
1933-1934-1935 Standards are the same. Right and left are the same.
Posts: 1,478 |
I have always got good results from Vintage Auto.
Posts: 183 |
Gene is correct; the axle shafts are the same! However, the rear brake drum is different on the '35 Standard. They are slightly wider than the '34. If you can re-use your brake drum you should have no problem!
flip
Posts: 14 |
Thanks very much for the inormation.
Posts: 14 |
Does Vintage Auto still exist? I can't get hold of them by phone and they do not answer mails.
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I have a used axle . If that will work for you E-mail me bwbugay@aol.com
