#362299 02/12/16 11:04 PM
MattD Offline OP
I've had no luck over the last 4 months on finding a 16-1/4" dia truck fan, '34 to '36. I notice the '37 to '38 16-1/4" fan has the same dimensions, will it fit on a'36 Standard 207 engine.
Matt
MattD #362301 02/12/16 11:23 PM
It will not bolt up to a 1936 or older water pump. Different bolt pattern and pilot hole.
Chev Nut #362310 02/13/16 01:11 AM
MattD Offline OP
Thanks for the quick reply! Do you have any leads on where I could find a '36 truck fan?
Matt
MattD #362311 02/13/16 03:45 AM
thavanko@yahoo.com
Tom may have one.
wisebri24 #362511 02/16/16 10:25 AM
The problem with a larger fan is that some will hit on the lower radiator hose so be sure before you buy one that the blades are not longer.
wisebri24 #373007 08/01/16 07:51 PM
MattD Offline OP
Hi, I haven't found a '36 truck fan yet. In your reply back in February you mentioned "Tom may have one," how do I contact Tom?
Thanks,
Matt
Matt
MattD #373015 08/01/16 09:43 PM
The correct dimensions of the truck fan blade is as follows-
Length, end to end 16 3/4 in,
Center 'Pilot' hole 1 1/8 dia.
Mounting holes bolt circle 2 1/16 in
Original GM Part NO.837448
Amazing difference! Fit my '35 Std 207" eng. perfectly
Temperature is about 20 degrees cooler than before!
Good luck with your search!
flip
I too am looking for a truck fan for my 35 Standard Coach. They seem difficult to find. If anyone knows of one please let me know. Thanks.
PeterV #373263 08/05/16 05:13 PM
Sign me up for a trunk fan too.
would be a big help in Calif. with 100 degree show days
36RAGTOP #373288 08/06/16 07:47 AM
http://www.patricksantiquecars.com/chevy-gmc-auto-parts.html
Try Patricks
Or
836968 shorter fan on ebay auction number 262559932764
