Posts: 724 |
Why have I, for many, many years seen 2 different size headlight trim rings for the 38 Chevy...One is larger in cross-sectional diameter than the other...Billu38
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
By "trim ring" are you referring to the part that clamps the lens to the housing?
ALL 1938's had the painted ring with a narrow chrome band...as did 1937's and early 1939 Master Deluxes. The 1937 and 193 are the same and the 1939 is a different size.
Posts: 724 |
It's the chrome band that I'm talking about....thx...Bill U
Posts: 724 |
Gene..was the 39 a smaller cross-section diameter than the 37/38? or larger? thx...Billu38
I don't know bt the 1939 lens is 9/16" larger than the 1938.
Posts: 724 |
Posts: 345 Likes: 1
Posts: 345 Likes: 1 |
Gene..was the 39 a smaller cross-section diameter than the 37/38? or larger? thx...Billu38 1939 ring is larger than the 37/38 ring
