Posts: 6 |
The letters cast onto my '54 210 wagon's engine are: CON2 A290.
Is this a 235 or a 261 engine? Where do I find this info?
help thanks
The numbers are only date cast numbers.The block casting number behind the starter will identify the engine size.
The 261 engine will have two little I I cast into the side of the block above the starter.
Posts: 6 |
Chevgene: ???I don't understand...block casting number BEHIND starter.(is it visible from above without removing the starter?)
???II above starter. (is that eleven or ii?)
thanks for the assistance
The I I are two raised marks about an inch tall.
The starter must be removed to see the casting number.\\What makes you think it could be a 261 truck engine?
Posts: 6 |
Chevgene:
The party I bought it from said a previous owner had put a crate engine with more cc's. AND, indeed, there are two II cast above the starter. I wonder what significant differences the 261 has? It's a shame it isn't the orginal, but it is a strong engine.
thanks for the help
The 235 cubic inch engine has a bore of 3 9/16' and stroke of 3 15/16" The 261 cubic inch engine has a bore of 3 3/4" and stroke of 3 15/16". Due to the large bore there is no water cooling between the cylinders. The carburetor on a 261 has a slightly larger throat.Other than that they are basicly the same engines. It there a stamped number on the ledge (facing up)-side of the block behind distributor?.
Posts: 812 Likes: 13
Posts: 812 Likes: 13 |
A list of engine casting numbers can be found at http://home.znet.com/c1937/Cast.htm . The casting number on 54 235 & 261 engines is located in a fold under the fuel pump. Only 1937 Export engines have casting number behind the starter. I have two 53-54 261 engines. They do NOT have the "Captain Stripes" (II) as the 56 and newer 261s. If your engine has been replaced, does it have a 55-63 Water Pump? Was the radiator screwed on the wrong side of the brace to avoid the fan?
Posts: 89 |
54Handyman: What kind of oil filter you have? Full or partial flow? How did you mount the engine? Which gearbox?
Mahar 51 Fleetline, 261, 3,55:1 94 Opel Omega 3,0
