cib Offline OP
I need to locate a 1928 Chevy transmission 3 speed refurbished or guidance to getting my transmission refurbished.
Hi, I dont know what you mean by "refurbished"....is it broken? worn out? ugly looking? Usually on these old things you just replace the worn out parts, clean it all up, and put it back in the car. They are really simple, not much required to work on them besides a hammer and punch, and some patience.
cib Offline OP
I was hoping for a rebuilt tranny,or contact info with someone who can do the job.or point me in the right direction,i really need some help.
It's a really simple gearbox. I guess the hard part is trying to figure out what parts are OK, and what parts are causing problems. For example, the transmission in my 28 was full of water, and looked like a mess. It did turn, though, so I knew it wasn't too bad. Taking it apart and cleaning the parts revealed some wear and a few good size rust pits, but nothing that looked like it would keep it from working. The most wear was on the back end of the input shaft (main drive gear), where the dog teeth meet with the internal teeth on the 2nd gear sliding gear.
I don't know how you find someone close by to work on an antique transmission. I've always just dove in head first, and figured out how to fix things on my own. It usually isn't that hard to figure out how to do it.
