Posts: 3,163 |
I just realized my LH rear frame horn is bent. Anybody know if I can bend that without heat? Thank you, Joe
Yes, it can be straightened without heating. Infact that would be the prefered method. You will be surprised as to how easy it will go back in shape if pressure is applied corectly.
Posts: 3,163 |
I was thinking about a long pipe. Yes/no?..Thanks Joe
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Joe, a long pipe might work. Just be aware that the pipe might dimple the frame where it contacts the end of the pipe. Putting a flat piece of wood or other stiff material will help spread the load and minimize unintentional damage. If you have a way to hold the frame down (I have tie-downs in my shop floor) then a floor jack can often be used to move the frame part back into alignment. It is more controllable than a pipe. I have use tree trunks, beams, timbers (sometimes with the pickup resting on it) to hold it down.
Posts: 3,163 |
Thank you Chip & Gene...Joe
