#371843 07/11/16 09:11 PM
DFC Offline OP
My '34 is a looong term resto started by another fella.Sixteen years
back he had 'Dog recondition the generator, starter and carb. As I now
have it started and running well I decided to check voltages in various
places. Across the batt with motor running I got 8.5v somewhat higher than expected for a known charged batt. But cutout relay to good ground showed 16-18v a surprise! I switched to another VOM and got the same reading. Switched out batteries and still the same. Very low charging amps <10. My old feeble brain is perplexed. What am I missing, guys?
Dan
The generator output at the battery cold normally is 8.2 to 8.5 volts. The amp meter should be reading around 8 amps when driving at speed, and no more than 10 amps max.
Did you polarize the generator when you installed it?
DFC Offline OP
Oh Boy! You got me there J.D. I forgot to polarize. First time in 55 years of automotive exploits. My dad from whom I learned the basics would have clunked me in the head for that.( maybe THATS why I'm getting feeble minded and I thought it was the durned meds).
Thanks J.D.
Dan
