#37170 11/05/05 02:47 AM
Can anyone please tell me or direct me to a picture or drawing that shows where the end of the carburetor return spring connects to the engine or frame. I must be missing a bracket of some kind because I cannot find out where this end of the spring goes.
Satisfaction is the death of desire.
xxx Offline
Can't help with where to attach it, but it make me think of the requirement of one club I was in which required all show vehicles to use a double return spring instead of a single spring...
I don't know how the VCCA feels about this safety feature or if it is really necessary. It did give me a feeling of some more security, real or not.
Takes away from original, but so does safety glass...
This is just for your information/consideration, I am just passing the thought on...however I would like to know if this is something that is OK by the VCCA rules or not.
5077chevy-What engine -6 or V8- and what carburetor???
The double spring was a late 1960's safty feature.If one spring would break the other would prevent the full throttle surprise.The best insurance that you could have is to install a new spring....I had a spring break on my '39 while driving on the freeway.It can be quite a surprise :o mad :o
This is on a 235 6 cly. Power Gluide. The spring sliped off of the spot I had it attached to and went to full throttle. Lucky for me it was when I was just starting it up in the parking lot.
The front hook on the spring connects to a small hole in the bell crank lever...the rear hook of the spring hooks to the block coolant drain valve.
Thanks Chevgene and the others for your input. I made a small bracket that I attached to one of the oil pan screws, that now holds the lower end of the spring. Not factory, but it will not pop-off unexpetedly anymore.
My '48 216 had the original bracket that you made
when I got it. Several older members saw it and
commented, "This is a real original engine because
most of the time, this bracket is missing and the
spring is just attached under the lip of the pan.
The 1952 was the last one to have the bracket on the lip of the pan.The 1953 and up have a different bell crank and linkage and it hooks to the block drain.The spring is horizontal rather than verticle on the 1953 and up.
I mailed you a picture of the 1953 and up.Thats what I assumed that you had for some reason. :)
Don't know if this helps but on my 54 235 in truck, when it was 3 speed, one end connected to a hole in the oil pan rail of block. When it became HydraMatic, the spring hooks to a block drain petcock towards the rear of block.
