Posts: 1,019 Likes: 3
Posts: 1,019 Likes: 3 |
Hello Everyone, I came across this item mounted on the firewall of a '37 Business coupe. The car had been purchased in California and shipped to Ma. Ballast for......?? ![[Linked Image from i1238.photobucket.com]](http://i1238.photobucket.com/albums/ff484/dfd37chev/20160629_193139_zpszqnmuqqb.jpg)
Posts: 1,513 |
Do a Google search on the information you have on the brass plate. I have no idea, could be something to do with the ignition system.
Posts: 9 |
It might be a ballast resistor for the ignition coil or for the instruments or for some kind of optional equipment . I am restoring a flat base cowl 1 ½ ton truck with a 216 engine at the Museum of Transportation in St Louis MO. Here is the wiring diagram for a 37 Chevy car. http://chevy.oldcarmanualproject.com/electrical/wiring/images/37car.jpgI have not see anything like the picture you posted. Good Luck
Should have done that to begin with.......per pics from ebay, it's an ignition coil. Mystery solved !
Posts: 9 |
Here are the specifications for the lamp. I found it at http://www.donsbulbs.com/cgi-bin/r/b.pl/1116dc~usa.html
category: Incandescent-miniature lamp volt: 6 amp: 4.17 / 3 watt: 25 / 18 base: BA15d - Double Contact Candelabra Bayonet (or D.C.Bayonet) glass: RP11 filament: C2V/C2V fil.res.: 1.44 ohm i.lumens: 402 / 264 cp: 32 / 21 d.hours: 125 / 200 notes: automobile lamp clear glass headlight lamp
