#37132 09/18/05 02:31 PM
I am replacing my 216 with a '54 235 and am thinking about putting a four speed behind it. I have a rear end out of a '77 Nova I could use. Any idea what transmision would work and if there are adapters available? Thanks.
#37133 09/18/05 05:27 PM
Check with Patricks in Arizona, he is a proponent of the 4 speeds in the 49-54 Chevrolets, and can supply you with the info or any adapters needed.
#37134 09/18/05 08:26 PM
a muncie or a t-10 4 spped will bolt to a 55 up 235 bellhousing. no need to buy expensive adaptors. mike
#37135 09/18/05 08:46 PM
trans. a saginaw 4 speed works great . i put one in my 48 p.u. with a56,235 and a 57 posi with 3.55 gears . contact patricks hes the guru on the subject. they are great to deal with and give you all the help you need . tom langdon of the inliners international is also helpful. i heard s-10 4 spd with overdrive is a good choice . im going to look into this one myself .kozy
Tom Koziol
#37136 09/18/05 08:51 PM
Thanks MrMack, I just emailed Patricks. Thanks Mike. Is '55 the first year of the open drive shafts? What do you think about the Nova rearend?
#37137 09/18/05 09:19 PM
55 was first year of open drive in chevy pass cars(vetes got em in 53) the nova rear wil almost certainly hold up to the torque/hp of the 54 235 ci engine you've picked.i'm not too fond of the saginaw 4 speeds as they don't shift as quickly as the muncie or t-10. don't know if s-10 4 or 5 spped trannys will bolt up to the 55 up chev pass car bellhousing. they are nice ss trannys and the 5 speed will give you the overdrive mode in 5th gear. mike
#37138 09/18/05 11:28 PM
A early T-5 warner 5-speed from a early S-10 truck would be the best choice. The early ones had a mechanical speedometer drive, the later ones were electric. The S-10 rear end and driveshaft is also worth looking at.
wdoftexas
#37139 09/19/05 12:27 AM
Thanks guys...as the man said, what do we need a moderator for, anyway!
"Counting the flowers on the wall don't bother me at all...watching Captain Kangaroo.....Now don't tell me I have nothing to do!!!!"
#37140 09/20/05 02:56 PM
Thanks everybody. I'll let you know how it goes.
