Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
I'm installing the interior in Bearsfan315 29' 4dr. I'm curious on the hardware used to hold the regulator in. Is it the same as a 31', with oval head 1/4x20 screws and depressed steel washers? If so, where can the depressed washers be had?
The depressed washers are normally called finish washers. Larger hardware stores should carry them in the bolt, screw, washer department.
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
We talking about these guys: My lowes and home depot carry them, nickel plated about $2-5 for 100 or so. Depending on size, or stainless for same price but pack of 6-8.
No, not the same shape. The ones on my 31' are more of a flat washer with a depression to fit the countersunk head. I have one extra from my car and I'll take a post a few pictures in the photo area. The depression sits better in the wider slot in the regulator board. The slots are 5/16-3/8" and the washer centers itself. The raised chrome finish washers I can get pretty easy in a marine store. I can use them, just not sure which type is correct.
TFS list Part No: AF-227 as the WINDSHIELD REGULATOR SCREW SET Stainless Screws with Nickel Washers This is a set of screws and countersunk washers to install the windshield regulator board in 1929-31 passenger cars. Set includes four large stainless machine screws. Also included are four large countersunk finish washers, nickel plated. The correct finish on the screws should be nickel. WINDSHIELD REGULATOR SCREW SET Picture
I do have nickel screws on my 31' but not those washers. I'll post a picture. Maybe mine are wrong then or possibly this is what is the replacement now.
I have posted pictures in the member's area to show the washers I have on my 31'. They really allow the screws to be tightened nice and tight to secure the regulator board.
Posts: 558 |
My 32 has the same washers as in ChisTech's photos...When I rebuilt mine, I thought they were odd but re-used them.....
Mac
Thanks for posting Gunsmoke so people don't think I'm smoking something! (pun intended!)
Thanks For Posting the Picts Ted (Chistech) I am a picture guy, helps me out a LOT !!
wonder if those are the Factory hardware, and what TFS Offers is a Modern Replacement ??
I have noticed that in working on the 1929 that there is some hardware that is no longer made, or was custom made. so creating or finding an modern alternate is he only way to go.
Then again maybe they changed sometime in the realm between 1929-1932 ?!?
Posts: 1,739 Likes: 2
Posts: 1,739 Likes: 2 |
The cupped finish washers that FS supplies are what is original on my 1929. These are available from Home Depot and Lowes as well as most any hardware store. The screws FS supplies look right on the outside but originals were brass nickel plated and have a point on the end.
Then again maybe they changed sometime in the realm between 1929-1932 ?!? That's what I'm wondering. Were the washers changed to what Gunsmoke and I have sometime in a specific model year. I know the FS washers are easily available but the washers I've shown I don't see anywhere. The FS type washers will eventually cut through the upholstery if the screws are tightened too tight or left too loose with vibration. With the washers I have, there is no sharp edge on the material, the depression fits into the slot in the board centering the board, and the screws can be tightened securely without fear of material damage. The 29' Coach I recently put the interior in had only one of these style washers and two of the new FS type (one screw was missing). This is what is leading me to believe the type Gunsmoke and I have is probably OEM. I need to do more research though.
Posts: 558 |
Might look to the F**D folks....My Dad used to call the ones I and Chistech have, finish washers....counter sunk washers that a wood screw would fit into.
Mac
Thanks Ted for making me do a history learning lesson ) lol ( that is why i love these old cars, learning something new every day What about this: flush washer --- A washer that is like a flat washer except that the center is pressed down into a cone shape to conform to the underside of a countersunk screw and the rim acts to spread the load out a lot more than is the case with a countersunk head alone.![[Linked Image from hobbithouseinc.com]](http://www.hobbithouseinc.com/personal/woodpics/images/flushwasher.jpg) They look very similar to what you have there in your pictures Other option maybe: flanged countersunk washer --- A countersunk washer with a flange around the rim to distribute the pressure on the clamped surface more widely![[Linked Image from hobbithouseinc.com]](http://www.hobbithouseinc.com/personal/woodpics/images/flangedcountersunkwasher.jpg)
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
My 29-38 parts book list #121770 C'sunk finish washer in Grp. 10.125 for the screws that hold the windshield regulator board to roof corner bracket for 29-32. In the standard hardware section 121770 is listed as 1/4" Chrome.
Posts: 687 Likes: 3
Posts: 687 Likes: 3 |
My 29 Coupe. ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_0638_zpsaap6xz2y.jpg)
I'm starting to wonder if both styles were used. What you found Jerry appears to be what I have in my car. So much thought into such a simple thing.
Yeah could also be a regional/ location thing. based on the factory/ plant that supplied the material and such. just like the type of wood and paint.
My 31' also uses the same type (flat w/depression) washers on the garnish moldings.
Posts: 31 |
Try Restoration Specialties Supply or Restoration Supply Company. Both have all manner of fastener, including the high head bolts and double thickness nuts used on the twenties cars.
Resto Supply has trim washers in SS, nickle or Chrome. I'd use the nickle as it's period correct, and only you will know..... and care.
Good luck. I've got to disassemble my 30 Sedans' and see what I have to do to get the regulator working, pestering forum members for along the way. AN opening windscreen is essential for Thirties coolness.
TOny
1930 Chevrolet sedan 1946 Chrysler New Yorker 5 pass coupe 1953 Dodge M37. (USMC)
