The normal oil pressure with a stock oil pump is about 15 pounds at 50 MPH nand 7 pounds at idle speed. This would be with hot oil, 10W-30 grade. When cold 15 pounds is normal at idle....if not a bit more.
If a later engine is installed with full pressure oiling the pressure will be about 35 pounds oon that 30 pound gauge at speed and the needle will be pegged.
I would guess you have just a stock oil pump which is more than adquate. The main bearings are the only thing that gets full oil pressure on a 216 engine and seeing the rod oiling is not tapped of the main bearings 15 pounds is fine. The rods and rocker arms get oil from the low pressure side of the oil distributor valve.
