Page 3 of 5 1 2 3 4 5
Just to let others know - If you are building a car that you want to have judged the under body was a medium gray color.
Hi Chevgene,
thanks for the interesting info. It Is not so important to me.Mine is from Chevrolet Argentina, the question arises whether the same colors were used. The outside color, by example, I could not assign.
Greetings André
1940 Special de Luxe Sport Sedan
https://1940specialdeluxe.wordpress.com
Chev Nut #407511 05/03/18 08:41 PM
Hi Gene, sent you an email, interested in seeing the factory frame colors as well. Were the frame and underbody the same color?
1942 Chevrolet Fleetline Aerosedan
1942 Chevrolet Fleetmaster Cabriolet
Daryl B.
BetoB #407514 05/03/18 10:12 PM
Email sent
Chev Nut #407636 05/06/18 02:13 PM
Think, that is interesting for us, too?
Greetings André
A lot of work has gone by. The engine is back in the car and the chassis is on the frame. I also glued some insulating mats on the interior. More pictures can be found here on Flickr.
At the Moment I reinstall all the Linkage for Throttle, Brakes and Shifting. And here i have a Problem. The upper Linkage does not fit at the Gear Box, at the Vaccum Shifter it´s perfect. In the Pictures I´ve made some Comments for better understanding.
When I did the Chassis back on the Frame, had to loose the Steeering Wheel clamps at the Dash Board, because the Steering Gear Bolts doesn´t fit in the Frame. Had to do the Gear Box about 1/2" backwards. On the Picture from the Steering Mast you can see the Marks from the earlier Position.
Is it possible that the Linkage does not fit in case of this? The other Steering Linkage Positions from the Manual are correct. It seems that the Position of the Chassis is a little bit too much backward, but all the Bolts fit - only the one on the left front doesn´t fit 100%. Tried to correct the Position of the Chassis - no Chance, and as you can see on the Picture, there is also not enough rest thread to adjust the Linkage. I could only remove the linkage and re-cut the thread?!
IMG_8096.JPG IMG_8098.JPG IMG_80981.JPG IMG_8148.JPG IMG_8151.JPG IMG_8126.JPG IMG_8155.JPG IMG_8157.JPG
Greetings André
Note the the car has right side steering and parts/location may be different from left steering.
More progress I'd like to share with you. The passenger side had to be filled and painted, also because of the accident with the rear door.
https://vccachat.org/ubbthreads.php/topics/291418/re-what-a-desaster.html#
I painted with an airbrush gun. I think it is really good and the color difference is relatively small.
IMG_8172.JPG IMG_8173.JPG IMG_8181.JPG IMG_8183.JPG IMG_8228.JPG IMG_8236.JPG IMG_8248.JPG IMG_8231.JPG
Greetings André
The next big step was to attach the front section. So that the whole looks again like a car. Unfortunately I had to find out that the left fender didn't fit at all. Unfortunately it cracked during the adjustment. It was already very rusted and thin. So there was a lot of sheet metal work to do.
IMG_8280.JPG IMG-20190323-WA0012.jpg IMG_8290.JPG IMG_8291.JPG IMG_8318.JPG IMG_8304.JPG IMG_8317.JPG
Greetings André
Since there was no painting under the lamps and also no gaskets, I had to rework also here. The screwing edge of the fender had to be repaired and also the parking light attachment was perforated.
IMG_0052.jpg IMG_0055.jpg IMG_0045.jpg IMG_8323.JPG IMG_8325.JPG IMG_8326.JPG IMG_8330.JPG IMG_8331.JPG IMG_0228.jpg 9DAA2044-2C95-4644-913C-C067002612D3.jpg
Greetings André
I spent the last week getting the overhauled engine running. After 2 days of failed tries I finally realized that I was trying to ignite the engine on the fourth cylinder all the time and it finally ran. A great feeling and an important step Forward
Greetings André
woohoo beermugs carbana
Russell #38868
'48 4 door Fleetline
Sounds good. Glad to see you are making progress. That sure is a nice shop you have to work in.
Last mounth i’ve got back the car from the upholstery. The interior is in creme velour. The windlaces are made with ”žoldtimer“ fabric and foam roller. Door handles, rear shelf and finger tipps at the sunvisors are in brown leather. The headliner was purchased at Rockauto. Very fine work!
315A7071-1AEA-47E3-AAE9-7154781DCA5E.png BB389B45-B300-41B2-AF1E-D92A404B688F.png 354BFDEE-1852-44F9-A4C1-CF3CAEDD5BA9.png B4565882-0639-4D94-881B-37E75BB3D43F.png 91ED1F19-FFF3-4506-BF58-EFE7D3324C48.png 1ED79415-399A-4FB4-869A-4E22BB5DBF0B.png E2DA73EA-3C8E-4CB2-8F96-57BF416ABE92.png 660DF939-6EF1-47A6-BC4B-DE89E83FA3AC.png F0BC3C1C-9EC8-4B2C-8C63-361F4A31F4BF.png 19048EE1-9235-425A-AD0F-0C71D04C6821.jpeg
Greetings André
More Pictures
6ECE4D09-77D7-4712-AB42-67F15A6B0CFF.jpeg C88563FB-012B-416D-A896-9986ECC2AC51.jpeg 424EF85C-AF97-432D-AAAB-BB3ACDF3B835.jpeg FFA26CE3-3178-4C0F-9B5C-C4C61EF9BCBC.jpeg 69A640FF-4F0E-4EE4-8B30-0898EB8C78B7.jpeg 7E6C8965-0E42-49A9-81D4-F497DCFC55A6.jpeg
Greetings André
Looks great! Much better when you consider it is being done across the "pond" where resources for Chevys are not the same as here.
Looks like that upholsterer knows what he is doing and has done a good job.
Thanks. Want to buy by Le Baron, but they are gone. So there was no other way to get a new Interieur. Don’t know what i had to pay by LB(+Installation here), but that was really a big part of my Restauration costs. Because he had to restore the back armrests and the front seat was made a little bit higher at the back. The Sunvisors are a couples from the old visors and the new mechanics because the new visors from COT40s are much smaller
Greetings André
These days i made the first ride with my car. Feels great. Here you can you hear the first running of the engine.
https://youtube.com/shorts/uurj6il9oIQ?feature=share
Don’t no after years, but is this tok,tok,tok Sound correct? Or should i do some valve adjustment again?
Greetings André
Sounds much too much nise.
You mean too much noise?
Greetings André
To me it sounds like someone is in there with a big hammer, I would advise to get him out of there.
Reset tappets with hot engine as it slowly idles.Not as difficult as it seems. 6 and 8 thou feeler gauge, 5/8 spanner to loosen nuts whilst engine runs and a large screwdriver to fit slot whilst tappets jump up and down. Start at no 1 cyl and by the time you get to no6 cyl its not so bad and the tappets are quiet.
I think you would want to set the exhaust at 13, not 8.
Yes!!
What old216 says above!
Personally I much prefer setting not running... and cold.
The setting will end up being almost exactly the same once the engine is "properly" warmed up anyway.
This has been discussed in the forum before, and Chevrolet's own literature shows that the setting hot will settle out being the same as a cold setting anyway.
And without the noise, oil spatter, and hot parts to burn yourself on.
Also, much easier to tighten the lock nuts properly, and doesn't beat up your feeler gauges.
The noise I'm hearing on your video is unfortunately something deeper than a simple valve clearance issue.
Clearance produces more of a "clack" than a "tok"
Not sure what it is, but if you are really lucky it could be a bent pushrod touching something.
While setting the valves, and before taking anything else apart, spin each pushrod to make sure there is no wobble.
I'm hoping for ya that it isn't anything deeper than that! :-)
Ole S Olson
