as most of you know my car, 1929 Chevrolet 4 Door, is up In Mass with Ted [Chistech]. he is doing some structural work as well as the roof and interior. While it is away i was to be reworking the Drivetrain. Pull the engine & Transmission, strip down, clean up paint, put on rebuilt Rocker Arm Assemblies, new push rods, caps, etc...
Well i finally got around to working on it, yeah been about 6 months.
Started blasting some parts, priming and then painting.
Round one was the pedals:
Pedal 01
Pedal 02
Pedal 03
Pedal Primed 01
doing 2 coats of primer, then 2 top coats of Gloss Black
You're going to have a nice big puzzle to put back together when the car gets back down to you. Looking good on both ends.
Puzzle ?!? Wait a minute, I am no good At puzzles... Hopefully the Pictures I took will help put Humpty Dumpty back together ?!?
Here are some Pictures of Parts 1 Painted Up:
Parts 1 Painted 01
Parts 1 Painted 02
Parts 1 Painted 03
Parts 1 Painted 04
Batch 2 was blasted yesterday at work, until machine burst a line and I got a shower in Glass Beads...
[Parts 2 Primed 01
[Parts 2 Primed 02
[Parts 2 Primed 03
Question:
Should the Screw on end of the Starter Pedal been Bare Metal, or should it get Primed & Painted as well ?? Seems to be different material vs the rod and hardware.
Prime & Paint or Bare Metal
I know there is a rubber bootie that goes over it
The starter pedal was painted white with black grooves to form a bullseye effect.
Mine appears to be aluminum. I couldn't see any paint on the aluminum, but the steel parts have black paint.
Just curious what kind of primer are you using. I have some parts bead blasted and I am wondering if Rustoleum Rusty Metal Primer would be ok.
Pete
The starter pedal button is aluminum and it is painted as described above.
I only use Rustoleum on garbage cans and wheelbarrows.
Probably the Standard coupe would be the same.
The Rustoleum was recommended by AutoZone, however I am considering the POR-15 from FS. I know there has been discussion on this subject previously.
Rustoleum spray valves are often defective and the propellant usually runs out before the can is empty. Krylon is a much better product.
If you have old Chevrolets, other old Chevrolets will find out where you live.
I always use a self etching primer. My painter told me it's the only primer to use.
Love this place. I learn something new everyday!
The starter pedal was the same for all vehicles in 1930.
I rate POR-15 right down at the bottom of the list along with Rustoleum.
Would the white and black bulls eye pattern be the same in 1929?
What paint do you recommend?
Thanks, Pete
Well I am using the Rustoleum Professional
PROFESSIONAL Primer Spray
PROFESSIONAL High Performance Enamel Spray
It is more expensive than the cheap Standard Rustoleum BUT the NOZZLE is a MILLION times better, sprays out even, and continuous, can spray upside down, sideways, and inside out. Goes on great, and seams to be very durable and worthy. Been using it for years now with no complaints, and beat the hell out of other things i have primed & painted with it. But follow the instructions on how to Top Coat and timing !! I blast all my parts, then clean them to remove any residue, oil, etc. I wear Gloves so no oil from my skin gets on the parts. then prime, wait 45 minutes, prime, wait 45 minutes, then top coat, wait 30 minutes, top coat. then let parts sit and cure for 48 hours before handling. Man they look good :)
Every can of the Pro i have use so far Paint last until there is NOTHING in the can, and does not Sputter or Spit paint everywhere. also very comfortable nozzle as well. Paint runs out before the Propellant every time so far.
Time will tell...
I am sure there is better out there, there always is !!
this would be the raised portion white, the recess grooves black ??
and would the entire aluminum piece be white ?? other than the grooves, or just he face of the pedal
based on this i assume the rubber cover was NOT standard on the 1929
Originally Posted by BearsFan315
Thanks BF the parts look great. I'm going to try it on the small parts.
Yes.
The entire starter pedal was painted white, and as mentioned above, the grooves were painted black.
Thanks JYDog !!
Appreciated, also noticed I have the Rubber Cover on my shelf, brand new from Steele. Now debate do I use it or not :!>?
Blasted a few more parts today...
machine was fixed and cleaned, and now works like a champ, took me 20 minutes to blast and clean all these parts to bare metal !!
1929 2 Blade Fan
I did my best to straighten it out and such BEFORE Blasting, so When i Paint it should be OK
Fan Blade
Misc Brackets
for: Splash Pan, Carburetor, & Radiator Elbow
Misc Parts 01
Misc Parts 02
1929 Air Cleaner
1929 Air Cleaner 01
1929 Air Cleaner 02
1929 Air Cleaner 03
Tonight will be prime and paint... Assuming all are Gloss Black :)
Nothing like a good machine to blast with. Your wheels, rims, lugs, and clips are on the way to the painter today. Roofing material goes on tomorrow. Moving along and will be coming home soon!
well got all those part painted up and looking nice:
Fan Blade
Fan Blade 01
Other Parts
Misc Brackets
Misc Brackets
1929 Air Cleaner
Air Cleaner
All Ready
Collection
Now on to the larger parts...
Manifolds
Starter
Generator
Horn & Bracket
Splash Pans
Apron
Last will be
Engine
Transmission
Well Horn is underway...
Rebuilding a Klaxon 8C Horn
