Posts: 47 |
I have not come accross any mention of what to do with the starter motor when converting from 6 volts to 12 volts. Can the 6 volt starter be used? :confused:
Satisfaction is the death of desire.
Posts: 79 |
No problem. Your 6 volt starter will LOVE 12 volts.
Good luck with your car.
DCMatt
What becomes of the day for those who rage against it?
Posts: 47 |
Thanks; It is still in the planing stages to switch over to 12v, but I want to have of the bases covered. Thanks again.
Posts: 89 |
But don´t overuse the starter or it will overheat, as it will be running faster and with higher voltage. In Tom Langdon´s site there is a good article on that conversion: www.stovebolt.com
Mahar 51 Fleetline, 261, 3,55:1 94 Opel Omega 3,0
Posts: 47 |
I have a idea. I had a 12 volt altenator from my Corvette and they sell a "wide" pulley replacement for about $20.00 for it. Can I use this with some bracket modifications to mount it the altenator?
