Posts: 95 |
"I'm making the setting brakes on my Chevy AC 1929 and I doubt that some brake rods and levers dont is original. I'd like to know the size (length)of: 1) brake pedal pull rod 2) service brake idler lever-rear 3)rod that goes from brake cross shaft lever-outer to service brake idler lever-rear 4) service brake pull rod rear (from service brake idler lever-rear to service brake lever). I dont find this information on the owner manual and repair manual. Thanks to those who can help me" Saluti dall'Italia
Posts: 95 |
Is it possible that only me have a 1929 Chevy. Cheer up! Help me! Saluti dall'Italia
Posts: 1,513 |
I have a 1929 I will try to find which parts manual I have that showed the length of the brake rod's you also might be able to find the information on this link http://chevy.oldcarmanualproject.com/
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
I have a 1929 4 door, but my car is not with my currently so can NOT measure what i have on hand.
Did some searching in my Master Parts Price List 1929-1930, & Master Parts Price List 1929-1932 no lengths mentioned in either, but the part numbers are as follows for the rods required. Also looked through my Repair Manual Chevrolet 1929 & Instr Oper & Care 1929 International AC Nothing on lengths
Part # Description 355974 Rod, Service Brake Front Pull, Front 355975 Rod, Service Brake Front Pull, Rear (Series AC)
355973 Rod, Service Brake Rear Pull, Front (Series AC) 385785 Rod, Service Brake Rear Pull, Rear (Series AC)
Posts: 687 Likes: 3
Posts: 687 Likes: 3 |
My 29 Coupe is in pieces. I hope these pictures can help. ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_0565_zps7jdrudnh.jpg) ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_0564_zpsklpoflub.jpg) ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_0563_zpsypyihygm.jpg) ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_0562_zps2dnxivqn.jpg) ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_0561_zpshosbahdx.jpg) ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_0560_zpstu835zlz.jpg) There is a short rod on the handbrake which I have not shown. Let me know if you need more information. Pete
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
Pete, you're a good man to do that for Alfredo..........
All the Best, Chip
"It's wise to choose a SIX"
Posts: 95 |
Pete, you are awesome. Your pitcures are outstanding and they are perfect for my work. I would like to ask you one last effort. Can You tell me the size (length)of the: 1) lever idler which is located between the rear brake tie rods (your pitcures 2 and 3) 2) lever idler which is located between the front brake tie rods (your pitcure 4) I hope you understand what I wrote ( my English is dramatic, I'm better with the Italian) Thank you again and ... Saluti dall'Italia
Posts: 95 |
I'm sorry, a last question. The black numbers that I see on the tape measure, they are centimeters or inchs? Buona giornata, Alfredo
Posts: 1,513 |
The black numbers are in inches. red numbers are in centimeters
Posts: 687 Likes: 3
![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_05701_zpsajo6gcji.jpg) ![[Linked Image from i1055.photobucket.com]](http://i1055.photobucket.com/albums/s505/Barefeetpiet/IMG_05691_zpsdqmsuy31.jpg) Sorry I don't have a metric tape measure. All dimensions black and red are inches and fractions. The smallest lines are 1/16". To convert Inch X 25.4 = Millimeters. The small idler is 4 5/8" approximately 117.5 mm. The longer one is about 7 3/4" or about 197 mm. Let me know if I can help. Pete
Posts: 95 |
Pete, you helped me a lot. If I have other questions, I'll ask more help. Saluti dall'Italia
Posts: 980 |
"I'm making the setting brakes on my Chevy AC 1929 and I doubt that some brake rods and levers dont is original. I'd like to know the size (length)of: 1) brake pedal pull rod 2) service brake idler lever-rear 3)rod that goes from brake cross shaft lever-outer to service brake idler lever-rear 4) service brake pull rod rear (from service brake idler lever-rear to service brake lever). I dont find this information on the owner manual and repair manual. Thanks to those who can help me" Saluti dall'Italia Service brake: Pedal to cross shaft - 13 9/16" Front rod - 26" 2nd - 29" 3rd - 19 11/16" Rear - 26" Hand brake: Front rod - 33 1/2" Rear rod - 27 3/4"
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 95 |
D2D2, thank you very much you too. Saluti dall'Italia
Posts: 980 |
Thank you all in Italy for pizza, Verdi operas and Alfa Romeo autos.
Posts: 95 |
