Posts: 53 |
On a 29 Chevy Coach is there any type of support for the accelerator rod prior to going through the wood floor board. Thanks
Posts: 46 |
No sign of such refinement on my '31 Coach.
Learn today, teach tomorrow...
On a 29 Chevy Coach is there any type of support for the accelerator rod prior to going through the wood floor board. No.
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
I added a metal plate with a smaller hole than the larger hole in the wood. Did it on the 30 when we had it and on the 28, works fine just make sure the hole in the metal is large enough to not cause the rod to bind.
Posts: 1,966 |
I used a piece of 1/4" rubber, about 2" square with a 3/8" hole, fitted it around linkage (cut a slit) and secured it to floor boards with 4 small screws. Works perfectly, cut similar square out of floor underpad so it does not show. Was concerned I would get a scraping sound with a steel surround/
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
Hey Gunsmoke, got any pictures you can post or email on your set up
Posts: 53 |
Thanks All Makes sense to me.
