#369136 05/25/16 11:49 AM
I am working on getting a 29 Conv Land Sed running for the NW meet in Medford. The head got cracked on 3 cylinders during a meet in 2014 when the owner accidentally "overheated it real bad". For a fellow who had been running late 20s cars most of his life to say it was real bad it had to have been almost red hot. Part of the reason was the temp sensor was not working well. My question is: last year there was a technical article about rebuilding the 29 heat sensor, does someone remember which months the two part articles were in the G & D?
beachbum #369151 05/25/16 03:19 PM
The article I remember is on rebuilding the 1929 temp dash gauge. Article was August 2014. There may of been a article later on building the sender and I missed it. There is a lot of good material in that article. The end of the article mentions that the next issue of G&D will have how to repair the sender. So September 2014.
Hope this helps. You might be able to message the author and ask.
Craig
Not till I have done and seen it all will I go peacefully.
beachbum #369166 05/25/16 06:57 PM
The Filling Station has new old stock 1929 temperature sending units. Billy Possum has them as well.
http://www.billypossum.com/
is there any way to figure out IF the temperature sending unit is bad/ defective. working on rebuilding/ painting my 1929 engine and would replace if i can.
You can test the sending unit with an ohm meter or test it on the bench with a power supply and a working 1929 temperature gauge.
I think Skip means "temperature gauge".
I have one of the NORS sending units from Billy Possum in two of my 1929 cars and they both work great.
All the Best, Chip
"It's wise to choose a SIX"
Chip #369178 05/25/16 08:10 PM
Right! I meant "temperature" gauge and I was editing my post while you were apparently making your post. Looks like we both caught it at the same time.
Chip #373348 08/07/16 04:47 PM
Hi
I have some problems with 1929 sending units. Please send me your contact number.
Cecil
beachbum #373366 08/08/16 02:10 AM
When I changed out the cylinder head I found that at some point in the past someone had used teflon tape on the sensor threads. Since the system works with the bi-metallic strips sending current to ground the tape was preventing that current from going to ground. On the tour in Medford it worked pretty well. The car did still overheat a little but discovering the cracked head 3 weeks before the tour I was pleased that we were able to complete all 350 miles of the NW meet tours without significant issues.
