#368867 05/21/16 12:26 PM
Genem Offline OP
Any idea where i can get a front wheel outer bearing washer # 6.321 for my 30 standard coupe
I would say it is a generic part used for nearly a century, and a local auto parts place should have something in either Dorman brand, or Help brand.
As long as the specs are for the same axle thread diameter, and if it has the tang, it should work.
here is one on the Dorman site, for 3/4" if that is what you have. Click where it says specifications, for the thread size. It comes with the nut. They have other ones to look at, under "front wheel bearing washer"
http://www.dormanproducts.com/p-6861-3049931.aspx?origin=keyword
I will have a 1929 front bearing apart today, if you need a measurement, as I would think it would be the same size
The washer's the same from at least 1926-32?
CJP'S 29
the washer, part # 3663991, fits 1929-1960 cars except 1933-36 Standards, also fits 1/2 ton trucks.
