Thanks. It took almost 1.5 hours of heating, rotating, and tapping to get the inner part of the plate free. I saw some red dust in one spot after 1/2 hour, so I kept at it.
I did needle scale the whole thing first. Then propped up the propane torch under the flywheel, and would rotate the flywheel a few inches every 5 minutes.
The springs are rotted/broken and maybe I have some V8 valve springs that will work. All 4 fingers/levers are stuck, as well as the slide hub. Should free up OK.
I could hear a piece of metal in the clutch disc area as I rotated. It is 1/2" or so, and is in the pic on the cast ring next to the short broken spring. Not sure where it came from yet, but the edges are all rounded from being in there a long time.
Now I will call my old friend tonight to see if he has a starter and ring gear...and a radiator.
Here is how I test started the motor with a missing starter, and many missing teeth on the ring gear. I wanted to know if the motor was good before I worked on the clutch.
![[Linked Image from i34.photobucket.com]](http://i34.photobucket.com/albums/d105/dailydrivervw/DSCN0574_zpshe4xu7yj.jpg)
