#368168 05/08/16 10:55 PM
I need to pull the outside trim (Stainless on the side of the car)from the outside of the car. Could you please provide information on how to remove this trim. I want to save it and put it back on the car.
The car is a 1940 Special Deluxe 2 door.
I am ASSUMING the stainless is removed the same as it is on my 41 sedan. Generally, a combination of fasteners/clips are used to hold stainless in place, although some areas of the car like the hood/grill have stainless that is held in place by tabs that bend. Some fasteners are screwed in place others are pressed, some have screw/nut combinations. Stainless is best removed with observation, caution, patience, and gentleness. The same techniques you use in the courting process.
My choice of tools is a thin bladed 3" long putty knife (a wider size could be used if it doesn't feel too clumsy, a thicker 1 1/2" putty knife, and a set of 1/4" ratchets with 6 sided sockets. With a really uncooperative clip I may use 2 thin 3" putty knifes and sandwich between them my thick bladed 1 1/2" putty knife for prying.
Stainless is usually held in place with clips spaced about every 6 inches. You may want to take a felt permanent marker and mark where they might be. This will help you know where you will need to pry UP on the stainless. Always assume that there will be a clip about 1" from the end of the stainless. I always pry up from the bottom of the stainless not the top. If you damage the stainless in the prying process you do not want it to show.
Generally, you will pry up by sliding a large thin putty knife under the stainless as close to the fastener as you can without hitting it. Your goal is to remove the stainless with out bending it, it is not to worry about salvaging every clip. Most clips will survive if they are not badly rusted. It is not uncommon to have a variety of clips used so caution is necessary. You want to slip a thin bladed putty knife under the stainless and pry up less than 1/8th." You are just trying to break the tight seal between the body surface and the stainless.
Start from one end of the stainless and go to the other. If you can not pry up on an area then look for a fastener behind it that may be held by a nut. Most fasteners do not require any interior panel removal except in the trunk. Failing to lift the stainless easily just move about 6 inches left or right where the next clip should reside and pry, eventually you should find an area where the putty knife can penetrate under the stainless and move it slightly. Locating a loose area means you are doing things the right way. From this loose area try to move to the left or right and loosen more of the stainless.
Eventually, you should be able to slide the putty knife easily under the entire bottom of the stainless, With this accomplished you can now work at lifting up the stainless 1/8" to 1/4" along the bottom prying with your three putty knives sandwiched together. The goal is to pry without bending the edge of the stainless or denting/scratching the body paint under it. Once you have established the space under the entire length of stainless just keep enlarging it until the stainless pops off.
Never try to run your putty knife under the entire width of the stainless unless you are planning on painting the car. The process of lifting up on the stainless might scratch the paint surface, bend the clip, and dent the stainless where the clip resides. Most clips are designed to be pried up from the bottom or top not pried straight out.
Different styles of fasteners are removed differently and are used in different body areas. I assume the factory may have even interchanged some. Door fasteners might be different from quarter panel fasteners, hood fasteners different than grill, and likewise rocker panel stainless will have its own style.
Time to have breakfast. Will take some pictures and cover each style of fastener.
Good luck, Mike
P.S. I'll edit this later
Disclaimer. The information I am providing is specific to my Master Deluxe Sedan.
The first picture shows the side molding fasteners used for my stainless. The fasteners used for the hood and above the grill are not going to be covered in this article. If you need that info let me know and I will cover it in another post.
The top right fastener is used on the cowl. this fastener is typically rusted beyond reuse so I made two. I bent the round edges with different diameter nails using my bench vise.
The left top fastener is 1" long and used for holding the door beltline molding. The spacing on these clips are one every 4" (not 6" as posted above). By looking carefully you will see the edges of the clips are bent over to allow the stainless to snap on and unsnap off the stainless. There are 6 clips on each door. When re-installing the stainless the clips are first installed in the door holes then the stainless is snapped over them.
The bottom left fasteners are for use on the stainless rocker molding. The right one actually is bolted to the body. The other fastener snaps on and is pried off. It is 1 1/8" long. When reinstalling the stainless this fastener is mounted in the holes in the body first then the molding snapped over it
The wire molding fastener is used for the rear quarter panel. It is easily pried away from the body and then pulled off. The wire clip is pre-mounted to the stainless and then pushed into place 6 holes in each quarter panel. The holes start at the door jam. The bottom 2 left clips are used to anchor the stainless inside the trunk. Either style clip can be used.
Best wishes, Mike
P.S. A very small fastener like the top left one is used for side window stainless on the Special Deluxe Models. Side window stainless is pried off just like the stainless on doors. There is also a very small piece of stainless between the two side doors on 4 door models. This stainless is held on by a fastener that requires removing a nut. Do not try to pry it off.
I have a 1940 Special Deluxe and if your's has the original trim fasteners the beltline stainless is held on with the fastener shown in the upper left hand corner of Mike Buller's picture. The beltline trim should be pried off from the bottom up off the fastener as Mike has suggested. Then remove the fastener by squeezing it. The stainless trim around the windows is held on by a different bayonet type of fastener which comes off with the trim when it is removed. The window trim should be pried straight up or out to remove.
