hello once again,
I had a 50' Chey parts car that I removed the rear leaf springs from, one spring has a broken leaf. On my 51' Chevy I also have a spring with one broken leaf. There is a reliable Co. in Tampa called Tampa Spring and they said they will rebuild my springs- meaning they disassemble, clean, re-arch?, repaint and install new bushings for $130 a pair. New ones through chevy's of the 40's cost $300 not including shipping (i'm not sure if bushings are included). Has anybody gone the rebuild route? If I where to rebuild the springs how do I remove the metal covering on the springs before I give it to the repair place. Is there a left and right spring?
Also, are there anymore opinions to my posting about the rear differential case and axle bearing dated 7-19-05 or 7-20-05. Thanks again for your help!
51Steve
