Posts: 47 |
The small copper oil line that runs from the oil pump up past the push-rod and to the center of the rocker arms is plugged solid. I am wondering if I can replace the copper line with something like an oil pressure gage line that is made of hard plastic.
Satisfaction is the death of desire.
I would not trust it. Why not replace with like equipment?
Posts: 47 |
For some reason, it has become very hard to find 3/16th copper tubing around here. I had the same problem when I was going too replace the vacuum advance line on the distributor.
Deleted by sender :confused:
Posts: 47 |
Thanks for the catalog link there is alot of good stuff there. I did drive to Fresno and I did find enough to do the job.As always you guys know the answers.
