#36778 06/20/05 11:26 PM
Who knows where to get the tools to properly remove and replace camshaft bearings on 235 engine?
macourtney
Some parts stores in this area rent cam shaft bearing installing tools.......My advice would be to have a engine machine shop install them properly.....The cost of renting the tool,ruining a bearing or two,and buying a seconed set, etc will cost more in a long run.
Thanks Chevgene, i'll check around.
macourtney
Thanks for the info, we can close this subject. I found a local speed shop that will remove and reinstall cam bearings in a bare engine for a nominal fee.
macourtney
