My 29 Chevy have a problem on the right rear axle shaft.
The wheel hub get in (enter, insert) too much on the axle shaft and pushes against the axle shaft retainer bearing (the retainer it is almost broke).
I think that the cause of this is the wear (consumption) of the hub or of the axle shaft (both conic, tapered).
But I do not know if it is consumed the hub or the axle shaft or both.
I do not want to change the hub nor the axle shaft.
Someone can give me some advice for how to fix this problem?
How can I avoid that the hub wheel slips (insert) too much in the axle shaft?
The hub should stop before 2 or 3 mm (more out).
Now the tolerance between hub and shaft is approximately 0,5 or 1 mm (gauged at the point where the hub should stop it).
You tell me if I did not understand.
I'm sorry for my bad English.
Saluti dall'Italia.
Alfredo
Of course the correct way to repair this is to determine which piece is badly worn and replace it. You could remove both right and left brake drums and exchange them -- that would confirm which part is worn (axle or hub or both). While they are off, use Vernier calipers or micrometers to measure all the parts.
Since you don't want to replace the parts, the second best way to repair this is to have the worn parts built back up using metal spraying technique. That works well and will make them like new, but it will be somewhat expensive.
The third best solution, and an old mechanic's approach to this, is to make a shim from thin sheet metal, cutting it exactly to size so that it does not interfere with the keyway for the square key. It will be a trapezoid shaped piece. Something about 0,5 mm thick should work. It is not a great solution, but it is an inexpensive one.
Good luck with your repairs.
All the Best, Chip
"It's wise to choose a SIX"
If you take option 3 then just make sure that the key and key slot are in good condition. If the axle nut is tightened enough and those parts are in good condition it makes a reasonably secure repair. Was done often in the past.
Thank you all.
I'm going to mesure the tollerance and I'll let you know.
Saluti dall'Italia
All ok.
I have make third solution.
I have make a piece with sheet metal (mm. 0,2)and ... all right.
The wheel is straight as a sword (I hope it lasts).
I continuing with other repairs (I keep you informed ... ?!?!)
Greetings to all.
Saluti dall'Italia
