#313381 07/19/14 04:44 PM
Ladies and Gents
Anyone know where to buy a hub puller, I broke my homemade one and driving around in circles has not worked. The wheel to be removed should be on the inside of the curve maybe it does not matter, maybe I should spray some PB blaster on it.
Ken
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Ken_Naber #313384 07/19/14 05:46 PM
I bought my hub puller from Sears. It is a Craftsman.
Ken_Naber #313386 07/19/14 06:30 PM
I am not making a plug for this auto store, but..... at my local Autozone you can rent (use for free) many different types of pullers and other auto related tools. Maybe check with your local auto part supply house and see if they have the same program.
Mike Quezada
(559) 250-5427
mike.quezada@M2ProSol.com
Qman #313393 07/19/14 07:27 PM
You could make another one like this:
https://vccachat.org/ubbthreads.php/ubb/showflat/Number/227893/
Rustoholic #313452 07/20/14 09:34 AM
Rustoholic
looks like you had lots of fun making that puller.
Ken
Ken_Naber #313453 07/20/14 09:40 AM
Junkyard Dog
I was thinking about my hub puller for my 1953 Packard while I was posting my quest. I had to remove the wheel all but hub to get wheel nuts on studs (that type plus from stud and not hub cap) and messed up a stud in the process but I got it off. That was disk wheels.
I put on wood spoke, the Sears puller I got would not work on that, you need an old fashioned puller. I would like to have one of those anyone know someone making them?
Ken
Ken_Naber #313457 07/20/14 10:01 AM
Hi
one more question, one side had shim and other side did not, which is correct?
Ken
Ken_Naber #313536 07/21/14 12:26 AM
I made mine out of a steel hubcap. I think these were made for trucks but the threads are the same. Drill a hole in the centre and weld on a nut. Screw in a bolt with a tapered end and you're good to go.
I always always loosen the nut a few turns and drive around the block making both left and right turns to get the wheel loose.
Arend #313569 07/21/14 01:29 PM
Arend
Just got a steel hub cap off ebay. Thank you very much.
Ken
Ken_Naber #313605 07/21/14 07:45 PM
That's a good thing. I gave one to a cousin who owns an engineering works to modify. He said "Not a problem". A week later it came back untouched along with four others that he had made up in a CNC. Same idea just a lot heavier.
terry hicks #313713 07/23/14 05:28 AM
Terry
he should sell them on ebay or VCCA for sale
Ken
Ken_Naber #313732 07/23/14 01:15 PM
For the benefit of all concerned. If you need a hub puller that is durable and will work, contact: George McMurtry, P O Box 112, Bayard, NE 69334-0112, 308-586-1930, (C)308-631-1454, gmcmurtry@embarqmail.com. Mention Ray Holland
Agrin devil
Thank you Ray, you are the best!
Ken_Naber #314978 08/07/14 07:39 AM
Hey!
look what I got
[Linked Image from forums.aaca.org]
Ken_Naber #314982 08/07/14 08:13 AM
Ken_Naber #315061 08/07/14 10:44 PM
Wow, that is amazing. That really is a seriously heavy duty puller.
terry hicks #315068 08/07/14 11:53 PM
What does it say around the top?
Agrin devil
Ray
was told MOSCO WALTHAM HUB WHEEL PULLER, says Mosco
thanks, I am thinking I know where another one is. if you want let me know
Ken
Ken_Naber #367042 04/22/16 01:49 PM
This is old but for the people that use the search functions. I thought I would add some info.
I could not get one of my wheel hubs off and tried everything. Even made up one of these https://vccachat.org/ubbthreads.php/galleries/227893#Post227893
I almost broke down and purchased a custom puller here: http://customhubpullers.com/
But I decided to sacrifice a dust cap by cutting off the top and using a traditional puller and it worked!
[Linked Image from s31.postimg.org]
Didier #367043 04/22/16 02:17 PM
Didier, congrats!! Looks like a good solution.
The hub caps are much less expensive then a hub puller.
Didier #367067 04/22/16 07:41 PM
All of you need to be aware that George McMurtry is a long term VCCA member. Not only does George make hub pullers but can often help with other tools and information on how to make and/or use them. He is a real asset of the VCCA.
Ken_Naber #367288 04/25/16 11:50 PM
I got one from Gary Wallace
1925 Chevrolet Utility Express PU
RichW #367311 04/26/16 01:28 PM
I got lucky and found one on eBay for $20.00 wink
