Posts: 193 |
Hi Can anyone show me a picture of a 1930 air cleaner and how it fits? I have been offered an air cleaner, but it does not look as if it would fit
PeterW
Posts: 127 |
peter, i just looked at my '30 coupe air cleaner. it is a grey, domed disk, maybe 4 1/4" dia. and about 1 1/4 " thick. there are many cut breathing louvers in the forward side (carb. side). it attaches to the aft side of the down draft carb. hope this helps. jim
jf lewis
Posts: 193 |
Hi Jim, Thanks that. But is it a down draft, surely the Carter carb is up draft? Can you tell me, is there a pipe between the filter and the carb and is the filter flat or vertically fitted?
PeterW
Posts: 127 |
peter, i think i miss stated the carb type; dyslexic, you see. the '30 has an "upside down" type of carb. sorry for the confusion. updraft, you are right. the air filter is vertical, domed surface facing the firewall. jim
jf lewis
is there a pipe between the filter and the carb There is a pipe that goes from the air cleaner to the oil filler tube.
Posts: 269 |
If you go to Hershey a vender has one. I looked at it but realized it was slightly different from the 31's. I can give you more info.
31 Chevy Roadster 64 Corvette 76 Corvette 77 Grand Prix
Just be aware that the '29 looks alot like the '30 air cleaner. The difference is the '30 has the air passages on the carburetor side while the '29 on the back side facing the fire wall.
Posts: 193 |
Hi Dan, Thanks that picture makes much clearer what I am looking for. Thanks to everyone else for their information Peter
PeterW
Posts: 193 |
Hi I have managed to source an air cleaner from Gary Wallace, but no tube to the oil filer. Can anyone tell me what this tube should be made of?
PeterW
