37Freak Offline OP
Hi!
I have an input shaft from REPUBLIC GEAR K222-1A W42A.
Is it for car or truck(carburized)?
Thank you!
Tino
37Freak Offline OP
Hello!
Are only original GM gear parts for trucks are marked with this blind holes?
Or were these markings adopt by aftermarket suppliers?
Thank you!
Tino
According to a old Republic book it is for both.
37Freak Offline OP
Thank you for this information!
Looking at shop manual truck and car gears should not be mixed.
Should does´nt really mean it is forbidden.
But in the post from MotorOnPushnPop
https://vccachat.org/ubbthreads.php/ubb/showflat/Number/144369/Searchpage/1/Main/23505/Words/carburized/Search/true/Re:_1937_tranny_problems#Post144369
he wrote "The shape of each tooth, the so called tooth profile is slightly different on the truck gears..."
It seems that real car gears where not made by aftermarket suppliers.
Tino
37Freak Offline OP
Sorry!
One more question. I read in the shop manual, that only 3/4 and 1 ton trucks had carburized gears.Cars and 1/2 ton trucks had normal gears.
Is there a remark in the old Republic book that K222-1A W42A is for 1/2 ton truck?
Tino
Yes cars and 1/2 tons.
37Freak Offline OP
Thank you!
That helps a lot to sort my transmission spare parts.
Tino
