#366570 04/15/16 01:18 PM
lynda Offline OP
Can anyone advise us on how to get the hood hinge pins out?
We are spraying with WD-40 and so far have gotten the center pin to move but the other two are not cooperating.
Lynda
I use my cordless drill to take hood hinges out....Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
The best is 1/2 ATF (automatic transmission fluid)
1/2 a hot paint thinner.
good luck
Dulty
I use liquid Wrench and a cordless drill
break them loose gently then twist and pull out slowly
Rotating with drill is the easiest method. If a hood hinge pin won't move one direction reverse and try again. Installing with the drill also works well.
