#365774 04/04/16 08:46 AM
cabboy Offline OP
Would anyone have a 1928 Cabriolet and would be willing to share detail photos of the top bows, hardware and windshield header area? Thanks for any assistance.
Welcome to the VCCA site...
You've got two posts about cabriolets, the first mentions a '28, and the second a '29. Is it two different cars, or a typo on one? Where are you in Canada?
cabboy Offline OP
Hello,
I am in Oshawa. I have a 1929. Asking about 1928 as there are similarities even though wood framing and sheet metal is different. May hardware parts are common as listed in original parts books. If I can't find info about 1929 I am hoping maybe 1928 info could assist. Particularly around the windshield header and top bow arrangement with hardware.
Regard
There is a Kijiji ad that keeps popping up with a cabriolet on it. Maybe you could contact the seller for parts or info...
http://www.kijiji.ca/v-classic-cars/london/1928-chevrolet-cabrolet-project/1153566250
cabboy Offline OP
Thank you, I will check on it.
Regards
cabboy Offline OP
Re: 28 cabriolet in Kijiji. Looks like he has it sold and it has been butchered. Too bad.
Still looking.
Hi Robin yes some of the internal bracket are the same but the timber and the measurements are different. if you contact Verdon's classic castings they had the header board castings and also the pivot at the top of the back end of the doors, they also have the top rests that you would fold the top down onto.Please note the rests are different to 28 and are shorter in height and you could also try Bill Carpenter classic chey wood he has done some of the roof bows using Dick Oldenburg originals for a template.The timber posts and header boards are nothing like that of a sedan or coupe the windscreen is also for 29 only it is different to 28 and the sun visor brackets that are repo are for sedan and coupe the Convertible cabriolet has a wider screen and sun visor so the bracket does not scroll out wide enough to fit the cabriolet without some slight modifications.hope this helps. jim
Jim
cabboy Offline OP
Thank you very much for the info. Everything will help get this car back to its former glory.
Regards
cabboy Offline OP
Couldn't find Verdon's via Internet or google search. Could you give contact info?
Thank you.
cabboy Offline OP
Hello again. Could I get contact info for Bill Carpenter as well?
Thank you.
Verdone's Custom Stainless Castings Marge Verdone 31 Strickerstown Loop road Newmanstown PA 17073 USA PH 717 949 3341 verdones@evenlink.com
and the Wood is Bill Cartwright 470 Rock Church road SW Willis VA24380 ph 540 789 8300 wwwchevywood.com
Sorry about the wrong name for the wood I think was having a senior moment
Jim
cabboy Offline OP
Hi Jim,
Thanks, I will check out Verdone's. I recently contacted Bill Cartwright and he said he does not do 1929 Cabriolet wood.
Have you tried Jim Rodman @ Autowood Restorations, 219-797-3775? He shows 29' sport coupes so I wouldn't think the Cabriolet would be that much different.
cabboy Offline OP
Yes I contacted Jim and he also indicated he did not supply wood for 1929 Cabriolet. The Cabriolet has most all wood different then the sport coupe.
Regards
cabboy Offline OP
The e-mail address for Verdone's would not work. Is it correct?
Regards
cabboy Offline OP
Hello,
I am still interested in acquiring detail photos of the top hold down hardware for 1928 Cabriolet. I have a very early 1929 and some of the found hardware does not match what I have seen on later 29 so I wish to see if mine used earlier hardware.
Thanks in advance.
cabboy Offline OP
Hi still looking for interior pictures if anyone has one. I would like to see the inside of a finished one.
Regards
