Posts: 260 |
I am reinstalling the front fenders and front grille splash pan. There is a bolt adjacent to the radiator. The splash pan, fender and chassis hole line up. How in the world do you gain access to place the nut under the chassis. I am thinking to bolt the splash pan and fender with the nut above the chassis. It has been about four years of removing parts. Any advice is appreciative. Jmm
Posts: 65 |
I think that is the same bolt I spent a day on it. It was the worst bolt I ever run into, I finally got it but it was a nightmare. Dulty
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
There is a special nut that is actually a clip nut that slides over the chassis rail. It is the Filling station part FS-538 called a "front fender anchor plate". I believe this is what you are talking about.
Originally there was not a separate nut but a "U" nut, speed nut or clip nut. It is a threaded flat steel bar stock that clips onto the frame. You can buy them from the Filling Station part number FS-538 listed as "FRONT FENDER ANCHOR PLATE"
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
cool... so we are talking about this: FRONT FENDER ANCHOR PLATE
Posts: 1,513 |
BearsFan I tried to open your photo and it will not open. I get a thing at the bottom of the screen to open a file from parts123.com
Posts: 42 |
Hello, Is there no other material / rubber or something else between the frame + fender ( only the 2 U nuts as a distance part ?) and between the fender + the above sitting front apron ( only the hexbolt head also as a distance part ? ) Any suggestion, recommendation ? Brgds. Norbert Coach 3D AE
Posts: 1,966 |
A rubber pad (about 1.5"x2"x1/4" with a 3/8" hole)is placed between the rad apron and the fender. So the machine screw has to pass through apron, pad, fender and then into the C-Clip/nut. The clip nut spaces fender about 1/8" off frame to help prevent rusting/rubbing. I found I had to leave the fender mounting bolts a bit loose to get everything to line up, as you indicated, not an easy job. A second pair of hands helps, and perhaps an awl. GL
Posts: 42 |
The mentioned rubber pad (about 1.5"x2"x1/4" with a 3/8" hole ) = Filling Station # AF 114 | Radiator splash apron cushion rubber |
Thanks a lot BTW - If mounted closely to the frame, a perfect hiding place for frame rust !
