Dad and I are working on the 31. We have put the steering all back together and we got an issue with it. When turning the wheel at certain positions we get like a bind/growling noise. It only happens when there is a load/ car on all fours if it is up in the air we don't really have the issue. Any help or if anyone has had this issue please let me know
33yr member/3rd generation member
Andy Jurski #42092
Family collection:
26 collector cars:
20 Chevrolet's
2 Ford
1 Oldsmobile
3 Pontiac's
My 31 steering is a problem also. I tried to take the slack out of the steering wheel using all the info I could find, when I get all the slack out of the pitman arm then left turn gets too tight. I installed a new section arm to the pitman arm, didn't work. Keep posting so I can learn how you cure your problem .
Dulty
Steering column bushing could be your problem. It may need a little lubrication. When you turn the steering wheel especially when there is stress on the parts the steering shaft maybe start straining/rubbing against the side of the bushing. I had a similar problem when I first put my roadster together and found that a little lubrication ended the annoying noise.
Paul
If it isn't broken, fiddle with it anyway so you have something to repair.
1931 Deluxe Sport Roadster
1953 BelAir 4 dr. Sedan
1965 Chevy II Nova SS
