Posts: 164 |
I know this topic has been discussed several time, but when I reviewed the search, I did not see any resolution. I have an engine block that I acquired several years ago that has 30/31 written on it by someone. I was looking at the serial number and it is 5229597 on the outside pad and also under the side cover. No M or any prefix. The water pump is in the block like a 35. Does this number fall into the 35 year?
1935 engine numbers ranged from 4708995 thru 5500178
Posts: 145 |
Gene's right, you have a 1935 Master motor (no prefix) built in June.
Mike Boteler 1935 Master Technical Advisor
Posts: 164 |
Posts: 3,292 |
1935 master motor 1935 standard series motor , SAME THING.
mike
While the bassic engines are the same the head could BE DIFFERENT and the intake manifold is different.
