#364833 03/20/16 05:00 PM
Since the engine on my '32 is out for a rebuild, I thought I'd take the radiator to a shop for an inspection and cleaning. Good thing I did. Every tube was clogged bad ! Luckily I found an old school shop here in CT that specializes in hand rodding and repairing antique radiators. They were amazed the engine ran at all. That explains the needle preferring the HOT side whenever slowing down or stopped.
Anyway, I stumbled upon an in-line filter device that is designed to catch any rust/scale being thrown off by the block from entering the radiator. Even after my engine is hot tanked and coolant passages scraped clean of scale, I thought this might be a clever monitoring and prevention tool. I'd like any feedback from anyone running one of these ? Obviously not original, but either are many of the fuel filters we use and it could always be removed for judging I suppose
Link to the one I found http://www.ganofilters.com
I have run a piece of brass or aluminium fly wire, scrunched up into a cup shape, and inserted into the top hose. This has caught all sorts of junk, you just have remove and clean it out a couple of times, then it can be taken out and left out.
Cheap/free !
Good idea. Fly wire ? Do you mean like window screen ? I've read the Gano filter is popular among vintage Ford Mustang owners. Seems those blocks can slough off rust particles forever. After spending a small fortune on a re-build, I'm anxious to see how clean she stays.
Yes , window screen stuff . 1-2mm holes will catch most of the crud.
