Posts: 21 |
OK, I know this has be discussed before, however I am confused which is not unusual. Here is the situation: When I purchased this '47 the owner only told me one thing and was the car was a positive ground (and I could see that it was). I did the usual fixes brakes, fan belt, points, plugs,rotor, rotor cap, new batter, new cables ect. Now I am almost ready to test drive it and I noticed a wire loose at the voltage reg. After looking much closer both generator wires are hanging loose and not connected. So now I am going to remove the generator and voltage regulator and take them to a shop for checking them out. The shop manger told me he could check them out and polarize them together. He took the serial off my old generator and looked it up on his computer and it stated negative ground. So I had my '42-48 blue shop mannual with me at the time and the diagram on page 12-22 shows the + going to the starter. On the bottom half of the same page 12-22 it show the truck electrical diagram and it to show neg. ground. Now I thought all the time that it was positve ground. Which is it???? Help Need some feed back asap. thanks rsh47
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
How is the battery wired? Positive to the starter or to ground. It should be negative ground.
Posts: 21 |
Keith, when I put the new battery and cables on I put it back as it was and that was negative to the starter (which of course is positive ground). But according to the shop manual it should be neg. ground. The reason that it confuses me is because I thought that I had read several times on the forum that that the '47"s where positive ground.
thanks rsh47
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
thanks rsh47 VCCA forum stating '47 is a positive ground ? No, the 1947 is NOT a positive ground. Don't know of any Chevy being a positive ground. Here is a schematic from the '42 to '47 shop manual. NEGATIVE ground only. http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm1232.htm
Yes, Chevrolets are Negative ground.
Did it start and run with it wired for the positive ground?
Posts: 21 |
Yes, it starts and runs.
rsh47
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
a link on this forum Note the first thread.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
It is supposed to be negative ground. Recommend you do whatever is necessary to straighten it out. Charlie
Posts: 21 |
The shop manual states neg. ground and all the forum feedback is the same, so I'm going to change back the way it should be to a negative ground. Steps: 1. Switch the cables after I change out the terminal with correct colors red (+) blk (-). 2. Switch the wires going to the coil as follow: wire from the ignition to + (positive) and the wire to the distributor to - (negative). 2. I had a shop polarize the rebuilt generator and voltage regulator to negative. So, I think I should be ready to do this job. I plan to do this Monday, but if you think I am doing something wrong let me know. Thanks......rsh47
If the ammeter read correctly then you will need to reverse the leads.
Posts: 21 |
Everything changed over to neg. ground today and it runs very good.
thanks for the input from all.
rsh47
