Posts: 48 |
Where does the forward end of the clutch spring attach?
Posts: 1,178 |
I will be under the 52 in a couple of hours and will check for you.
Posts: 1,178 |
Beginning at the linkage where the clutch is adjusted move forward to the front of the car along side the frame rail. Approximately 10" from the above location there is a hole in the inside of the frame rail. Two pieces are needed. The return spring and a piece of stiff steel wire bent with opposing hooks on the end. The steel wire hooks into the hole in the frame and onto the spring, hope this helps.
Posts: 48 |
Thanks glyn...I tryed to streach the spring to the hole w/o the wire and couldn't make it.Your info should help.I'm sure some of my question might sound dumb,but I'm trying to put this car together from parts I put into boxs 10+ years ago.
Posts: 1,178 |
I understand, except that any thing that happened more than a month ago can be a problem for me.
