Posts: 17 |
Does anyone sell lower door repair panels(skins) for 50 Chevys,front & back? Any and all help appreciated. Thanks
Posts: 6 |
Have you tried National Chevy Association or the Filling Station. They are on the web.
Jim
For the door repair panels, The Filling Station doesn't have that year listed in their catalog.
Posts: 23 |
Surplus Supply in Akron, Oh. has them (12" lower door skin) for $35 ea. www.surplussupplyco.com
Posts: 81 |
What about the ribbed aluminum peices on a 53 Belair that go on the rear door (4dr) and rear quarter panel under the stainless trim and Belair script- some are just painted white and some like mine have the aluminum strip? melchevyman
macourtney
The Bel Air 4 door has a ribbed stainless trim on the upper quarter panel just behind the rear door window.
The insert between the mouldings-just above the fender skirt - is painted a contrasting color or matches the top color on 2 toned cars.At the very front of the insert, above the large stainless stone shield there is a small 2 1/2" wide ribbed stainless piece on a Bel Air---its about 4 inches long.The psinted area is from there back.A 1953 had no aluminum trim and the Bel Air emblem is mounted in a painted area.
Sounds as if some one may have cut down an aluminum quarter insert from a 1957 BelAir and stuck it on a 1953.
Posts: 81 |
Thanks Chevgene I'M a novice at this 53 Chevy, have had other Chevys, but not a 53. Glad someone out there knows best. Thanks a lot melchevyman
macourtney
