Posts: 275 |
Hi Guys, I am having the fenders on my 29 repainted. The fenders were fitted with fender welt, however the running boards were not. They had a rubber strips between them and the splash plates and fenders. I assume this is not correct and that the previous owner ran out of fender welt. Am I correct in assuming that the fenders as well as the running boards should be seperated by fender welt and not plain rubber strips.
Regards, Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Posts: 275 |
Thank you, once again, Sir
Posts: 65 |
IF YOU WANT IT TO LOOK SHARP, USE THE SILVER WELT AROUND THE RUNNING BOARD, TURN THE OUTER EDGES BACK UNDER THE RUNNING BOARD TO HIDE THE END, THERE IS A FORD PLACE IN CA. SELLS IT ON LINE. DULTY
Posts: 65 |
thanks, I didn't know that.
Posts: 275 |
TKS Leon, Apologies, I hadnt seen your post re chrome coloured fender welt until now. Thanks for the advice, I'll definately consider your suggestion.
Posts: 65 |
You can buy it at Sacramento Vintage Ford Parts,Inc. 916-853-2244 www.vintageford.comremember to run the ends back under the fender to look sharp. snip the flange to make sharp turns. (silver welt) around the running board not the fenders. good luck Dulty
Posts: 275 |
TKS again Dulty, I was thinking that chrome all round the fenders would be too much, but now your suggestion ( only around the running boards) makes sense. Thanks
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
If not being judged however it's a good alternative in place of the high priced chrome trim.
Posts: 65 |
I also used it around the wheel wells, for the spare tires, it really looks good. Not good if you are going to be judged , its a no no. Dulty
