#36291 01/07/05 12:28 AM
How do I remove the crank case breather from a 216?
Thank You, Paul
#36292 01/07/05 01:49 AM
Remove the single bolt at the end of the support bracket. Insert a broom handle or similar object down the breather and start wiggling it till you can pull the breather out of the hole.
Agrin
#36293 01/07/05 11:49 AM
Seeing your 1952 216 will not have a oil cap on the breather it will be necessary to tap it back and forth a bit before pulling up on it to get it out.
