RonH Offline OP
How should I remove the spring bushing from the frame? Is it as simple and driving them out with a socket over the metal part protecting the pin itself.
[Linked Image from i1319.photobucket.com]
1936 Chevy Standard Town Car (Late model)
Basketcase
I had to heat mine up...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
RonH Offline OP
Thanks,
I should have asked.
Do I need to replace them at all if the rubber is still intact and the pin is still tight within the rubber??
Basketcase
Sorry Ron. I didn't realize yours had rubber. Someone else can take this one please...Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
You can push them out with two pieces of pipe and a large "C" clamp. One pipe must be large enough to fit on the bushing and small enough to pass through the hole on the frame. A cheater on the "C" clamp will help, too. On the side that the bushing is comming out on, place a larger pipe to receive it (into the large pipe)as it pushes out. The larger pipe gives you something to push against with the "C" clamp. It is that easy.
Ron,
My 1935 Standard had those pins pressed directly into the frame. No bushing was involved. Your setup is different?
THH Offline
You could use a ball joint removing tool. It's nothing but a heavy duty C-clamp, a socket that is the same size as the metal jacket and just push it out. Some places will rent you one. Installation is with the same tool, just push it in. I used it and it worked great.
Tom
