#361477 02/02/16 05:32 AM
hi has any one replaced the felt rear axel seals inner and outer with rubber type oil seals im told that skf 16406 oil seal will replace the outer felt seal??
johnhill #361502 02/02/16 04:19 PM
I have that same job ahead of me but I have not researched it yet. Maybe Dean will jump in here. He has probably traveled this road.
35Mike #361508 02/02/16 05:28 PM
Guilty as charged. blush
I only replaced the outer seals on Lurch. My reasoning was that I didn't want to mess with the inner seals. If some grease from the bearings seeps into the rear axle housing, that is fine by me. If some oil from the differential seeps into the wheel bearings, again, I don't care. Especially since Lurch doesn't travel much these days. Mostly on and off the trailer. At most, I'll drive him to a show that is less than 20 miles away.
I just wanted to make sure that neither grease nor oil seeped into the brake area.
I used SKF 16406 seals to replace the felt outer seals.
