Posts: 84 |
Can you buy replacement ball studs ? Looks like you could grind the back side and press them out. I see on ebay they have replacement tie rod ends but what about the drag link. This is on a 37 master coupe. Thanks the Honer
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I replaced the set on y 38 with Filling Station units. They have weld in and screw in. Tony
Posts: 1,478 |
I have pressed out and pressed in new ball ends. All I used was a shop vice on a work bench.
