Posts: 81 |
Does anyone know a machine shop that can convert Babbitt rods to inserted rods- at a resonable price?
macourtney
Posts: 29 |
Connecting rod insert conversions: Marc Hansen - EMS PO BOx 48227 Seattle WA 98148 (206)433-0564 See add in G7D
DonC 14476
DonC
Posts: 81 |
macourtney
Posts: 81 |
I have tried repeatedly to reach him but only left messages and he has not returned the calls, anyone else?
macourtney
Posts: 81 |
Another question along the same line? How many rod and main shims can be used under new babbitt rods and new main bearings? I am having trouble with rebuild my 53 - 235 standard. They are too tight.Checked with plastigauge shows over.0006. Thanks for a solution, besides grinding crankshaft.
macourtney
When new they usually had 4 shims on each side-2 .001" silver and 2 .002" brass.(rods and mains). How many shims do you have now?
If using plastigage is the engine up side down with the weight of the crank on the block side? I perfer using the "drag" method for the mains and the "tapping rods back and forth" for the rods as per the shop manual.
If you have new or good babbited rod bearings they are just as good as inserts.The 1953 has the thin babbit rod bearings and would stay "tight" for 100,000 miles if oil was clean, etc.If did require adjusting just removing a shim or 2 was all that was required.
Posts: 175 |
As far as changing to inserts, don't overlook checking local machine shops. I found one in my area that had experience and they converted mine when they did the machine work on my block and crank. Not a big deal, just bore out the big end of the rod to the insert bearings' specified O.D. and cut a notch in each half of the rod for the bearing tang.
The shop manual method of adjusting bearings as Gene stated works fine for these motors. Since your rebuilding, make sure to check the drag on the mains before installing the rear seal. It adds quite a bit of drag to the crank.
Bob
Posts: 81 |
I think you have ansered my question, thanks I only have one set, need probably three more for the Mains they are real tight, lots of drag. Did not get enough to start with.
macourtney
