#358901 12/27/15 12:14 PM
Andys29 Offline OP
While putting my headlight together I found that the insulator that has the two contacts for the bulb does not have the two tabs sticking out to prevent it from rotating within the socket. The insulator look new. I have not found a vendor that has the insulators with the tabs yet. Any ideas out there.
There is a number from Napa Echlin. I can't 100% remember the number but it's LS-6226 or LS-6228. It's just a pigtail..Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
Andys29 Offline OP
I looked it up on line and the LS-6226 is a signal contact and LS-6228 is double. You are 100% correct with the numbers. I will stop tomorrow and see if it will work. Thank You
You're welcome...Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
