Does anyone have experience with the Simmons Super Power aftermarket carburetor(updraft)for a 27 or 28 engine? I could use some specs (float bowl setting, etc) at the least and rebuild parts would be great.
I have a couple around here somewhere. Never tried to use one. The original Carter works well so am not motivated to try one yet. Don't have spare parts or specs.
According to a F**d discussion forum, the Simmons carb was used on Model As and Ts. Below is a picture and here's where the discussion is:
http://www.fordbarn.com/forum/showthread.php?t=91219&showall=1
[Linked Image from i193.photobucket.com]
Dean, Thanks. Good lead. Linkages differ, but maybe rest is similar. Dave
You are welcome. Google search is amazing.
Dean
