Posts: 169 |
Was needing the original diameter of the piston bores in the block for the 171 engine. I may need to have my block bored over and need the original size to gauge from. Not the piston size itself but the bore size in the block. Thanks
3 11/16 {To assist you in the work on the engine you should read the "School is in Session} If you are a member you have access to the Thread.
Posts: 3,511 Likes: 48
Posts: 3,511 Likes: 48 |
While we are talking about the bore of the 4 cylinder engines, how much wear is too much before the block needs to be sleeved or scraped?
Thanks, Dean
Posts: 242 Likes: 1
Posts: 242 Likes: 1 |
0.060" sixty thousands is the max oversize with a lot of piston manufacturers I do know of a person who went 0.080 eighty thousands oversize and has had head gasket problems ,they can blow through number 1 to no 2 or number 3 to number 4 easily.
Jim
If you check it early enough you can sleeve all 4 cylinders and it will be okay. I have never had to do all 4, but have done one at a time.
