Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
I have low voltage lamps on a heavy 8" x 8" wooden fence rail.
The lamps are powered by # 1141 12 volt bulbs. Being outside, the bulbs are binding/seizing in the sockets. Tough to swap out, when they burn out.
Is there anything I can put on the bulbs, to prevent the bulbs from seizing within ?
Posts: 935 Likes: 12
Posts: 935 Likes: 12 |
I have a friend who swears by WD-40 sprayed on the bulb base b/4 installing the bulb. Good luck !
I have a friend who swears by WD-40 sprayed on the bulb base b/4 installing the bulb. Good luck ! WD 40 ? OK, thanks.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Marine wheel bearing grease or lower unit lube. They are water resistant. If not solid they will not prevent the contacts to make a good connection.
Marine wheel bearing grease or lower unit lube. They are water resistant. If not solid they will not prevent the contacts to make a good connection. Not understanding this one, Chipper.
Posts: 1,513 |
I think they have a grease that is made for this problem. I can't think of name right now. Do a search on the internet might show something. Just remembered it is called a dielectric grease.
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
The major car parts places sell a "bulb lubricant" that is designed to do exactly what you're asking for. "Electralube" and "Bulb EZ" are two brands and there are several others. Don't know if it's any good, I've never tried it.
All the Best, Chip
"It's wise to choose a SIX"
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Dielectric grease is an insulator so could be problematic if it's gotten on the contacts. You want a conductive grease.
If the grease is too viscous or hard or has fibers in it, then it might prevent good contact between the bulb and socket. The lower viscosity grease and oil will get pushed out of the way and make good water resistant contact. I routinely use grease on battery terminals to seal them from moisture and acid gas. Have also used it on bulbs that are exposed to the elements.
